1 - 8 of 8 Posts
hi, yes i read the phenom2 guides, still didn't get it
my specs are below, [email protected], 785g mobo, ddr2 667
so i want to oc the nb, but...
1)what is the default multi-speed? is on auto in bios, one guide said 9 another said 10
2)my mobo has not mosfet cooling, should i do this? i know i can't up the volts
3)ocing the nb affects the ram? because my ram is not for oc, so can i do it?
thanks
Shouldn't be overclocking that far on that motherboard
4+1 power phase makes it all the more scary
You might be fine if you're not absolutely pushing the voltage though (for the CPU; the NB is less of an issue, it uses the split single phase and doesn't really take up much power). I do recommend you add mosfet cooling if you plan to continuously use that board at high clocks or voltage.
If you're not using the stock cooler also, stop immediately.
Reactions: sixor
my current oc is with default vcore, i just want to up the nb until i need to touch the volt, and off course if that is safe XD
thanks for your help
so should i do it? or better leave the nb default
Upping the NB gives out a big effect. The NB makes use of the single power phase (the "1" in 4+1 power phase); since the NB doesn't really consume that much power at all this is fairly safe, there are even a lot of boards that have an 8+1 power phase that OC well. Even a few notches up with the CPU-NB voltage should be fine, but don't overdo it.
Reactions: sixor
No, the NB and RAM are not linked. The only way you up the RAM is if you up the ref. clock from 200Mhz. Since the 965 is a black edition, you can up the Northbridge clock by simply increasing the multiplier.
-xd
Reactions: sixor
1 - 8 of 8 Posts
