I had a question regarding the Ncase M1 acoustics/sound/noise.
Although 90% of the system sound is dependent on your components I wanted to know about the 10% being the case itself. The Ncase M1 just loses it's side panels using clips instead of a sealed sliding door on most other cases. Do you personally think compared to the other cases there is a slight increase in noise using this case if u r aiming for a strictly PIN DROP SILENT build? I will ONLY be using the PC for surfing the new & word doc's so I don't want to hear any sounds from the PC AT ALL.
I will use a air cooler from noctua or bequiet for the build to get as silent as possible.
Would love your comments, suggestions, & advice!
