You're obviously not quite clear on memory. DDR actually stands for double data rate. So 667MHz is the effective clock speed of the memory. I'm not sure exactly with DDR2, but I think that your memory will only go to 767MHz effective.
Originally Posted by John600rr Okay, I'm a little confused about the whole RAM:FSB relationship. I've got 667mhz (PC-5300) DDR2 memory running in my system. Say I run my FSB at 250x4=1000mhz, my ram will only run at 1000mhz right? But my RAM has a maximum of 1334mhz right? (667x2). Would I be wasting that 334mhz I'm not using and just got PC5400? Should a person choose their ram based on how high they plan to run their FSB? Say I want to run a stock FSB of 800, their's no point to buy anything higher than PC3200 right? If I want to overclock and not run a divider, then I should get higher freq. ram? I know this is basic, but I'm looking for clarification. ![]() |
