I am looking to build a new system with a Phenom II. I need a motherboard that does the following:
1. has am3+ support (990x/990fx)
2. capable of core unlocking
3. has the ability to bench a cpu under DICE or LN2
4. costs less than 160 (preferably)
I plan on using a Phenom II x4 960t and unlocking it to an x6(yes, the 960t will unlock). Eventually, I would like to experiment with DICE and LN2 an possibly a bulldozer/piledriver CPU. Here are some options I compiled:
sub 160:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138341
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157281
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128510
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131754
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157266
over 160:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130600
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128509
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157267
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128508
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131735R
Preferably, I would like a motherboard under 160, but I'm willing to spend more if it is worth it.
Thanks!
sub 160:
over 160:
Thanks!
