1 - 19 of 19 Posts
Originally Posted by shiarua
dbpoweramp music converter
http://www.dbpoweramp.com/
Does the free version allow me to do this?
If not, I'd like something free to actually use.
Discussion Starter #9
Originally Posted by Lurikrunch View Post
Looks like you already got something that works, but why not go 'official' and grab the FLAC Frontend? http://members.home.nl/w.speek/flac.htm
I used it to convert my WAVs from EAC to flacs, worked perfectly, and it has de-encoding (decoding!?) capabilities too!
I'm rather confused by the "documentation" on the website.
Do you know for sure if it'll do a FLAC to WAV Conversion?
Some Converters (I've run by just using google) just do WAV to FLAC
Try the "Decode" button... all you need to do is open your eyes!
Originally Posted by Tator Tot
I see the decode button. There's no reason to be rude.
I was just trying to make a confirmation before I actually downloaded the program and such.
You realize you can just try, right?
Implying that your time is more precious than someone else's = rude. Thanks.
Looks that way to me!
Instead of trying, you asked. I'm just being rude back to you.
You got your answer, right? Not being a nuisance to anyone, then. This thread would otherwise sink.
Rude or not, what you did was ask someone to do the work for you. Your time is not more valuable...
Okay, now that that is out of the way, yes, FLAC Frontend will go from flac -> wav and from wav -> flac. Use the Decode button to go flac -> wav and the encode button to go from wav -> flac.
I thought that much was obvious...
Originally Posted by Unstableiser
Coma's avatar is cooler so he wins.
Thanks man. I can hardly wait for my infraction. It's going to be extra juicy because I was rude to someone who was being rude! I'll take a screenshot and hang it on my wall.
whats wrong with Foobar ?
Discussion Starter #19
Danke for that answer.
I've had issues with it and trying to batch Encode/Recode files.
1 - 19 of 19 Posts
