1 - 14 of 14 Posts
I am on a budget on building my rig, i pick the xpm 2400+ as my cpu but now i need to pick out a good mobo to run that cpu for around $60. is there a board out there that will let me run at 2.4 stable.
Originally Posted by blob
Shuttle AN35N Ultra.
is there any other brand the would do? because newegg doesn't carry it and i want to order it from newegg.
thanks
Wow, newegg stopped carrying it. ***...
Don't worry about who you get it from, that is one of the simplest and best OCing boards for mobiles. Dont pay for what you don't need like Sata and other things. This board is solid.
http://www.digitallyunique.com/an35n-ultra.html
http://www.computergate.com/products...odcd=B7HAN35NU
Taken from a sticky on mobiles:
Will this work in my motherboard?
Reccomended motherboards:
Abit NF7-S V2
Abit AN7
DFI NFII ULTRA INFINITY
DFI LANPARTY NFII ULTRA B *Note the DFI Infinity and the DFI Lanparty perform the same
Nforce2 motherboards: Will work with any as long as your motherboard allows you to change multis. Depending on if you have a cheap mobo you might need a pin mod to toggle from the upper multis(12.5-24) to the lower multis (6-12)
Via motherboards: In most cases this will work, but a pin mod may be nessasary to change the multi's
Abit NF7-S V2
Abit AN7
HE left out shuttle board....cuz he sucks?
j/p get the shuttle if its alot cheaper than the others.
Discussion Starter #9
Is there a diffence between these Abit board s
ABIT "NF7-S" nForce2 Chipset Motherboard for AMD Socket A CPU - Retail
Supported CPU: AMD Duron/Athlon/Athlon XP Processors
Chipset: NVIDIA nForce2 SPP + MCP-T
FSB: 400/333/266MHz
RAM: 3x DIMM for DDR333/266 Max 3GB, 2x DIMM for DDR400 Max 2GB
IDE: 2x ATA 133 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2xPS/2,2xCOM,1xLPT,SPDIF Out,6xUSB2.0(Rear 2),1xLAN,Audio Ports
Onboard Audio: nVIDIA SoundStorm APU(Dolby 5.1) + 6-Channel AC97 CODEC
Onboard LAN: 10/100Mbps Fast Ethernet
Onboard SATA/RAID: 2x Serial ATA, RAID 0/1
Onboard 1394: 2 Ports
Form Factor: ATX
ABIT "NF7-S2" nForce2 Ultra 400 Chipset Motherboard For AMD Socket A
Chipset: nForce2 Ultra 400 + MCP-RAID
FSB: 266/333/400MHz
RAM: 3x DIMM Supports Dual channel DDR266/333/400 Max 3GB
Ports: 2x PS/2, 1x COM, 1x LPT, 6x USB2.0(Rear 4), 1xRJ45, Audio Ports
Onboard SATA/RAID: 2x SATA with RAID 0,1
Onboard Audio: 6-Channel AC 97 CODEC on board
Onboard LAN: 10/100M LAN
Form Factor: ATX
one is $59 and one is $81 ?
Originally Posted by bored7one4
Does all of these mobo that you guys suggested run the ram in dual ch mode?
All the Nforce 2 Chipset motherboards run dual channel... BTW stay away from the ABIT-NF7S2, it's a crappy overclocker. If you're going ABIT you want the AN7 or the NF7-S Version 2 (different from the NF7-S2)
http://www.newegg.com/app/ViewProduc...130-475&depa=1
This is the mobo i have its the MSI K7n2 delta2-LSR its a great mobo I like it a lot I have a xp-m 2500+ on it running at 2.6 right now. This mobo will run you 60$ incl shipping from newegg. Before I had my mobile chip in it I ran a desktop 2500+ barton @ 218X11 (2.4) stable with pc3200.
Discussion Starter #13
what kind of a PSU are you running
i was planning to get the antec case that comes with the 350 watt psu.
1 - 14 of 14 Posts
