1 - 20 of 21 Posts
What would be a nice laptop for a budget of $1500? I'm looking for a price-performance kind of thing. I checked Alienware and Dell so far..What you guys think? Recommend me a laptop or should I say "build" me one
With that budget you can get a good laptop.<br>
A customized hp would be 1517$ with:<br>
Intel Core 2 Duo 7200 (2.0 ghz)<br>
17" brightview 1680x1050<br>
512 Mb geForce 7600(i think it's a GS)<br>
HP imprint + microphone + webcam<br>
1GB RAM DDRII<br>
100GB 5400rpm<br>
DVD-RW LS<br>
and a<br>
High Capacity 8 cell battery<br><br>
That's a pretty good laptop, and you will able to play heavy games with it!
Go for the Asus A8Js....<br />
<br />
<b>14" TFT (WXGA+) Color Shine<br />
Intel Core2 Duo T7200 <br />
NVIDIA Geforce 7700 512mb dedicados <br />
2048MB DDRII 667MHZ<br />
120GB HDD Sata <br />
DVD RW SuperMulti Double layer <br />
802.11g wireless LAN- webcam 1.3mp -Rede 10/100/1000 - Win XP PRO - com mala e com rato<br />
2.39Kg</b>
I just bought a good laptop from ibuypower.com. They have excellent service and I got a:<br />
15.4inch (for low weight approx 5.5 lbs)<br />
Intel Core 2 duo T7200 2.0 ghz 4mb cache 667 FSB<br />
2.48 gb DDR2 ram 667 Corsair<br />
256mb Geforce Go 7600 PCI Express - I can post the comparisons of how amazing it is if you're interested.<br />
100gb hd <b>7200 rpm</b><br />
DVDr/rw CDr/rw combo<br />
<b>Fingerprint Scan Access</b> built in - hot for a laptop<br />
windows media center with free upgrade to vista<br />
Built in 1.3 megapixel webcam<br />
1 year warranty <br />
<br />
and some other various things you may not get like a flash drive etc. and the total was 1650 exactly.
whats a 7700?
<div>Originally Posted by <strong>vtech1</strong> <a href="showthread.php?s=5bd08cb0a2becf66ff9a516b8d226d15&p=1409162#post1409162"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">whats a 7700?</div>
</td>
</tr></table></div>
<br>
The nVidia Geforce Go 7700 is the newest graphic card of Nvidia..<br>
It has 512 Mb Dedicated and a GPU and 80nm...<br><br>
It does not perform as a 7600 GT, but it dont suck such juice... The 7600 GT, 7800 GS/GT and the 7900 GS/GT/GTX has GPUs with 90nm... Thats to you have the laptop always using the electricity...<br><br>
To me, its an excelent choice...<br><br><br>
(Sorry my english, but I'm a portuguese...)
Go with the asus
Discussion Starter #9
I'm back...minimum requirements are...must be 17" + webcam + internal tv tuner?<br />
<br />
do they exist?? internal tv tuners for laptops?
Yes, they exist... I know an Asus with those characteristics, but I don't remember the model... Go to the Asus site and search for it...
You can buy an external tv tuner , it will be expensive (100$) but you get more functionality than in an integrated tv tuner.<br>
//oftopic//<br>
i'm portuguese also!!!
Discussion Starter #12
<div>Originally Posted by <strong>[email protected]</strong> <a href="showthread.php?s=7cbacc57dd35bcffd2623e1b5502316d&p=1413056#post1413056"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">You can buy an external tv tuner , it will be expensive (100$) but you get more functionality than in an integrated tv tuner.<br>
//oftopic//<br>
i'm portuguese also!!!</div>
</td>
</tr></table></div>
More functionality? Such as what?
Get a 17" MacBook pro, and an Elgato tuner.<br><br><a href="http://www.elgato.com/index.php?file=products_eyetvhybridna&PHPSESSID=2ef5fd59b1b804b8176ce3b54a6cbf93" target="_blank">http://www.elgato.com/index.php?file...6ce3b54a6cbf93</a>
I'd recommend getting a mac book, now that they hve C2D's and start at $999.99, it's a pretty good deal. Also, if you need to have Windows on it, you can install XP using boot camp.
Yup. Those new macbooks look tasty ! Though I'm convinced you could find better specs for 1500$...
The external tv tuner would give you more functionalities like a component cable in(like ps2 one) and you could use it in any computer..........
I dont know if this has been said before but ibuypower.com does goood ones, I was gonna build a custom one ther for 1500 for a freind's gf and it was killer.
Old school
The Asus A7- has a 17 inch, A8 is nice too indeed.
<a href="http://www.ibuypower.com/mall/lobby.htm" target="_blank">http://www.ibuypower.com/mall/lobby.htm</a><br><br>
here check out the notebook section I bet they will have what your looking for.
I saw on some french forum that the a8Js are awful. Looking at it from the specs it might be really teasing, but some of the forum's followers said that it overheated way too easily, some had them crash in a few days, poor customer service... and the battery lasts barely 3 hours (awful for a 14incher...)
1 - 20 of 21 Posts
