1 - 11 of 11 Posts
I need a new Air Cooler for my Q9550, Since the fan just stoped working. I know there is lots of good ones. But my Case can only alow 131H mm. I found this Arctic Cooling Freezer XTREME Rev.2 Which I think will hold me stable up to 3.8GHz. What do you guys think or suggest? Remember heatsink dimension no more than 131mm in High.
Originally Posted by garricktlee View Post
CoolerMaster Hyper 212 Plus
You can find one under $30
Definitely best bang for buck cooler!
Yea but its over my case dimension 120 x 79.7 x 158.5 mm (L x W x H)
How about Freezer XTREME Rev.2?
Yes its a good cooler as well, its right below the hyper 212 plus and cost slightly more.
But if it fits in your case it should work great.
What about the Noctua U9B? It's 125mm tall and should fit your system just fine. The specifications are here.
Here's an image I found on the web showing this HSF in an SFF case:
Originally Posted by pcnuttie View Post
Get a H50, you'll be happy how temps are
This.
Originally Posted by Icejon View Post
I would suggest the CM Hyper N 520. It looks the hottest and performs well.
...that does look impressive, but it's 142mm tall.
Discussion Starter · #11 ·
Actualy, I just upgraded to new Antec 900 TWO Case. And bougth Xigmatek Thor's Hammer.
I think it was a great choice. Thanks for your help, I didnt even knew there is some good 131mm (H) heatsinks existed, untlil now...
1 - 11 of 11 Posts
