1 - 4 of 4 Posts
Wat
What components is it going to be connected to? If it's your current sig build it will do. Although I do recommend getting the HX series if you can afford it. Modular cabling is great.
Corsair HX650
Nothing wrong with the TX650 other than that you should be getting a better unit such as the Antec TP-650, which costs exactly the same. There's no sense in getting the TX650. It's a very good unit, just not the best you can get for your money.
1 - 4 of 4 Posts
