Need a Wireless router!
422 Views 9 Replies 6 Participants Last post by  monogoat
Requires:
Sub $100
Wireless N
USB Port to plug in a printer
Reliable
Fast
Thanks!
1 - 10 of 10 Posts
I thought printers used ethernet cords to connect to routers?
I could be wrong though, not really up to date much in current technology.
Printers with no built in network capabilities can connect to a router with usb.
you can connect via usb or if they have wireless capability you can connect straight to the router
the Dir-655 is a good router. Supports g or n at one time
Dir-825 tad bit more supports G and N at the same time
I've read the DIR-655 USB port is messed up, only supporting windows connect or whatever.
EDIT: I've also read now that a new firmware upgrade allows it to act as a local usb port for any computer on the network, is this correct?
If you search for this router on google and what not, you can definitely find it cheaper.
ASUS RT-N16
Like this
ASUS RT-N16
Like this
Is it better than the DIR655?
Wow that asus looks decent. On ewiz page fir that asus he linked to. It says it's buil for up to 300,000 p2p traffic or something. Basically it won't slow down
I would not have suggested it if I didn't think it was a decent router.
I've been looking at the WRT350N, if you are into DD-WRT firmware, you just have to find a deal on it or use egay.
1 - 10 of 10 Posts
