Hello.
I'm a new user here but not that new to over clocking. I just want to know how far I can push my pc, I'll run through the spec's and hope someone out there can advise me:
AMD 3200+ 2.0ghz (oc'd to 2.25)
2Gb Corsair Value ram (soon to be upgraded)
Asus sata 2 mobo
550w psu
2 x Thermaltake streetfighters (1 front suck in, one back blow out)
1 x Thermaltake Blue Orb
Current cpu temp. Idle 25 c
Mobo temp 26 c
Both temps are with Streetfighters on lowest speed settings.
Any advice would be muchly appreciated. I also have a question..........
I see a lot of people on here adjusting the Mulitplier to gain performance but mine does not seem to work.........I adjust the multiplier and 'save & exit' bios but when i go back to check the settings have gone back to default! Any ideas? I currently run 2.25 by adjusting the FSB.
Asus sata 2 mobo
550w psu
Mobo temp 26 c
