1 - 8 of 8 Posts
What mobo is the BEST i865 for OC PD 805. I had AGP graphic and 2GB DDR4000 so I cannot go with i9xx mobo.<br>
Or any nForce mobo that support AGP and DDR
Probably going to be one of these.<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813135164" target="_blank">http://www.newegg.com/Product/Produc...82E16813135164</a><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136156" target="_blank">http://www.newegg.com/Product/Produc...82E16813136156</a><br>
I would pick the DFI but it's out of stock right now. None of them that you find will be great overclockers though.<br>
EDIT: Nevermind. <b>These don't support the dual core</b>. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"><br>
These do, but good luck overclocking at all, sometimes they barely even support it at all, even though they say they do, they might not.<br><a href="http://www.newegg.com/Product/ProductList.asp?Submit=ENE&N=2010200280+1070509908+107171070+1072407534+1070617634&Subcategory=280&description=&srchInDesc=" target="_blank">http://www.newegg.com/Product/Produc...n=&srchInDesc=</a>
Get this and you can upgrade to core 2 duo later on <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813185086" target="_blank">http://www.newegg.com/Product/Produc...82E16813185086</a>
Here's one that supports DDR/DDR2 (upto DDR2 667) and AGP/PCI-E (only 4x instead of 16x), doesn't mention on newegg but it supports Core 2 Duo:<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813157092" target="_blank">ASRock 775Dual-VSTA</a><br><br>
Edit: Sorry it is not 865PE or nForce.
I don't think any of the i865pe motherboards do. You'll have to look for an alternate chipset I think. Like Via's offerings or something.
Yeah, I caught that in my edit. Anyways, why the 865 chipset?
Discussion Starter #8
Actually, any chipset that support AGP/DDR that can OC PD805 will work.
1 - 8 of 8 Posts
