for what? on a desk as part of a PC setup or in the living room as part of an HTPC setup or what?
they're pretty efficient so if they're going on a desk you don't need much to make them loud, my speakers are way less efficient at 83dB and I'm driving it with a ~100W RMS Klipsch PowerGate and @ 100% it's uncomfortably loud.
if you're putting them in the living room as part of an HTPC setup a full size receiver might make more sense and you might get more volume out of it but it'd be overkill as a desk setup.
Type: 12" 3-Way (12", 4", 1")
Frequency Response: 28Hz - 22kHz
Power Handling: 5/250 watts
Sensitivity: 97db
Nominal Impedance: 4 ohms
Crossover Points: 300Hz, 6kHz
Dimensions: 32" x 16.5" x 14.75"
Weight: 57 lbs. each
