1 - 8 of 8 Posts
· Banned
· Banned
Originally Posted by OptimusCaik;13107133
Would that set of heatsinks make a big difference over the stock EVGA one? And what fan/fan size should I use with that?
You need to buy the mounting kit, and the heatsink/fan, costing around 60 bucks total, but you will gain insane amounts of coolness
, I'll be getting one soon hopefully.
Originally Posted by Sethy666;13107164
Second this. I have had AC coolers on my GTX 275 and GTX 470. They are excellent air coolers... and very quiet
You need to buy both the fan cooler and the heat sink set.
http://www.aerocooler.com/shop.cart?action=ITEM&prod_id=FANACXPLUS
Cheaper on mwave.
I have 2 GTX 460's in SLI
Although in the links provided it says that they are "Crossfire and SLI Compatible," when i look at the dimensions..... they clearly aren't compatible.
I have about 30mm clearance before hitting the next vid card (I only have 2 PCI-E slots so I can't move one card down a slot). Is there a solution for this? Or am I missing something that would make these fit somehow??
Thanks for any help!
Just last week I installed an Arctic Cooling Twin Turbo II on my reference PNY GTX 460 1GB. I flat love it. Dropped my load temps in gaming from 75C down to 56C with the fan on auto. Amazing difference. Plus its very quiet (inaudible over case fans). Pretty straightforward installation. Got it for $37 at Mwave.com.
http://www.mwave.com/mwave/SKUSearch.asp?px=FO&scriteria=AA79371
1 - 8 of 8 Posts
