Need better CPU Temps (air flow)
996 16
case pics let me know what i might be able to change around to get better cpu/gpu temps
cpu- amb- 18c load- 33c
gpu- amb- 33c load- 58c
i labeled the in and outs of the airflow to try to make more sense
1 - 17 of 17 Posts
Other thread deleted. This thread renamed
Looks pretty good.
You could move your Sound card down. Comp USA sells a blue fan thing that will take air in from the outside and blow up on the GPU.
You could get a Big Typhoon. it is the best CPU air cooler out there.
All air should move from front(in) to back(out), and side(in) to top(out).
yeah i know,about the airflow thing, im just kinda limited right now as to what i can do without completely revamping or building another case. as for the gpu i'll look into that intake ur talkin about
umm it looks to me like you have some fans backwars... you shouldnt have the PSU fans blowing into the case,it should be blowing the hot air out the back.... but this guide will help you maximize the airflow, you have tons of fans so thats not a problem, just how they are set up is...
Discussion Starter · #9 ·
as said before, im just lookin for max flow of what i have now
um did you read the guide i linked you too? it will solve your problem buddy....
Discussion Starter · #12 ·
can yall not read or something? seriously with all do respect i said i didnt want to rebuild my case but yet u still continue to give advice that pertains to me rebuilding my case. maybe some like to read thier own voice. lol
Discussion Starter · #17 ·
well a little sincei built a pci slot fan, load went down probably 6-8, but eventually i will build another case since im rebuilding next year
guess im gonna go amd64 system next year they seem to be out powering pentium
1 - 17 of 17 Posts
