1 - 14 of 14 Posts
Hey guys. Im looking to build a super pc for around $1,000ish. I am looking into the following components and looking for a little advice. Let me know what you guys think. PS. Im trying to purchase these tomorrow at some point so any help would be greatly appreciated
$288.99 - CPU - i7 -
http://www.newegg.com/Product/Produc...82E16819115202
$239.99 - MOBO - EVGA SLI LE x58 -
http://www.newegg.com/Product/Produc...82E16813188049
209- CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model TR3X6G1600C8 G - Retail
http://www.newegg.com/Product/Produc...82E16820145236
$99 - HDD (Storage) - 1TB WD Caviar Black -
http://www.newegg.com/Product/Produc...82E16822136284
$289.95 - HDD (OS + Applications) - 80GB Intel X-25M G2 SSD -
http://www.newegg.com/Product/Produc...82E16820167016
$129.95 - Case - Antec 902 -
http://www.newegg.com/Product/Produc...82E16811129058
I Already have a beast power supply and XFX GX260NADBF GeForce GTX 260 Black Edition Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video ...
Lemme know!
also, I will be running Windows 7. Please point any unbalances or incompatibilities if I missed them. Also if there are any comparable components that you know I can acquire at lower price points help a fellow nerd out!
That's pretty much as good as you'll get, pretty much the same as mine. There is nothing on that list I would change besides maybe the case, but that is all preference[I would rather get the HAF 922].
It's fully compatible and the only way you can lower the price is to buy your 920 at a local microcenter if you have one.
edit: Oh yeah, pick up a CPU cooler if you don't have one. I recommend the dark knight for about $45 bucks or the Corsair h50 for about $80, both are great. The corsair I have is a VERY easy install. If you're not going to overclock/buy a aftermarket cooler, just pick up the 930 instead.
I'd go for a CoolerMaster case. They seemed to be of a better build quality when I was looking past week.
The 690 would be my choice.
Nice looking build though.
Enjoy
i'd get those parts if i was in the market for an i7 system.
nicely chosen
I would get these parts had I had your budget...I think its a great build!!!!
I would highly recommend going to a Microcenter, or get someone to buy you one from them there.
It would be a lot cheaper either way.
Unless you need to go Intel.. you could save a bit o' cash goin AMD, NewEgg has a PhII x4 925+ Gigabyte 790GX board combo for ~$265.
1 - 14 of 14 Posts
