need expert advice on OC gtx 260 216
992 Views 18 Replies 9 Participants Last post by  paras
hey guys as u know i have the sparkle gtx 260 216 cores or as in the sparkle way i have the gtx 260+ card ( the 2nd one in the pic SXX260896D3S-VM)
http://www.sparkle.com.tw/product.asp?id=93
now i was about to start ocing this beast and wanted some advice
ok now the default settings are according to evga precision are
core clock 576
shader clock 1242
memory clock 999
now i just ocled the card to 600 core clock and the temps were like max 55C when i played for 5-10 min
i got like 20-30 fps increase mayb
iam also not using a after cooler for my cpu or gpu and the game was very stable
i wanna ask is that shld i try to oc wat aspects of my card?
also shld i overclock everything or only core?
any other help or advice is also welcome
iam really a noob at ocling so plz guide me how to this
also i have an air conditioner in front of my case and when i switch it on the temps go down by 5-10 C
i have run some tests at different cores have a look
2nd test
core 700
shader 1400
memory 1100
fan 80
it worked for 10 min with ati tool with temp not reaching 60
and worked with l4d for less than 10 min(like 7-8 min) without a hiccup
now can any1 tell me wether i shld oc more or just settle for this?
4th test
core 756
shader 1512
memory 1152
fan 80 no error for 468 min in ati tool temps did not go above 63
also tested on furmark for about 5-6 hrs min and no error and temps 63
u guys think i shld stick with ths or shld go higher?
also wat other advice can u guys give me?
1 - 19 of 19 Posts
posting in a potentially epic thread
756core is a great overclock though.
i mean the oc is a new thing to me
after those tests u think i need to worry?
iam yet to play the game coz i dont wannna hurt the card
also i tried to go 800 core clock and the comp freezed so i think this will be my last oc
u guys think i shld test it in games now?
i think i did a good test still want ur advice on this before i start using this in games
You need to use it in games now.. applying Q features can stress the shaders a lot more, and reveal instabilities, where some synthetic benchies cant [mainly ones that dont allow resolution increases + AA].
Try gaming on your settings with 8xAA and 16xAF + a good resolution..see if it holds and monitor temps. If all is well, I would say, try for another 15-30mhz on each core and mem. Temps are really good..no doubt, what is helping you hold your shaders at 15xxmhz.
wow thnxs guys
ok ill do so i was so very worried
before i do that can some1 confirm that will i be shortnening the life of my card by OC?
or will this overclock result in any damage to my card?
ok guys wanna share 1 more thing when i restarted my comp the core clock in graph went 301 shader 601 and memory 100
now when i test with ati it goes back to 750 and all
so shld i think the card is resetting the values to low coz it cant handle the load?
or is it coz i had to manually restrat the comp?
I would lower the clocks if your temps regularly go over 70c.. other than that, nothing you are doing will affect the longevity of the GPU. Manufacturer rating for GPU cores is upwards of 90+c ...so dont worry about loading in the 60's.
Temps can limit your OC, so you may find, if your ambient temps change dramatically [ie- summer to winter OC's]. Mainly, for GPU clocking, you will hit either a temp limit- preventing the GPU from holding high OC's... or a voltage limit- in which the GPU would be running at its max speed, on its current voltage.
*I run heavily mod'd 8800GS's, and have for over a year now, with no issues. They are on water most of the time, which helps prolong their life running 1.32v ...up from their stock 1.08v
so u think i shld test more or just try in the game?
iam a bit scared that i dnt harm my card
wat is the worst that can happen?
Download OCCT 3.0 and run the GPU stress test for at least 30 minutes at those clocks and see if its stable. atitool and l4d aren't particularly stressful 3d apps, you better use crysis and furmark and run those for longer periods of time then 6 minutes.
..........Dude I reckon you'll hurt your card more on ATI -tool than in any game.
And by hurt I mean not hurt.
Your card will be fine.
Although your OC is incredibly high, I leave mine at
694 core 1158 mem, 1479 shader.
AND, if my ambient is higher I must put the fan on 100. Anything less and I get a lock up into low power mode.
Ambient temps are fine at the moment so I use my auto-spin up profile wich takes me to about 77% fan under full load.
Lower your clocks, and testing in the game is no different to the Stress Programs...if anything they are more stressful than any game except maybe Crysis.
EDIT: Just play the games. What will happen in case of a lock up is the game will freeze....simply press ALT - TAB into windows when this happens, wait a few seconds for the computer to get it's crap together, go back into the game (which will now be downclocked in medium or low power mode, because you tripped the card...then exit the game and reboot - your card will not retain max power until you reboot. but don;t just assume the computer's locked and reboot from inside the locked game...
dude i ran the test on furmark and atitool tog when i was sleeping i left both on and it ran for like 7-8 hrs
still i need to worrry?
If you ran Furmark for that long without monitoring it, two things are true:
1. You are at least partially insane.
2. Your card is absolutely stable if you did not get any crashes.
If you ran both programs simultaneously for that long without monitoring it, one thing is true:
1. You are completely insane.
Be careful when running stress tests. They are designed to make your card work as hard as it possibly can, and that is far more likely to cause damage to your card than a solid overclock and playing games for the next couple of years.
I can only reach 730 core / shader linked on my card before it begins to artifact. Don't forget that you can get artifacts in ATI tool that aren't reported by the program, so you have to actually WATCH it to make sure there aren't any problems.
If you can get as high as 750 and then some more, then you have one beautiful card.
ok guys i think ill stick with this OC
core 730
shader 1460
memory 1150
fan 80
was playing TF2 for 30 min or more and man temp did not rise more than 47 C
lols can u believe it?
ok now i wanna ask is shld i go beyond this OC coz i really dont wanna
my fps in TF2 did not go less than 25 i think but it was a 32 player server and my fps for most time did not lag as it did earlier and was above 30 fps mark 99% with all that happening
this is great and sry for running those tests like that
wont do it again i promise
ok guys any more advice or am i done here ocing?
core 730
shader 1460
memory 1150
fan 80
I suppose I can believe it, but then again, that's not too demanding of a game and we don't know what your ambient temperature is.
On the other hand, I'm glad to see that you're going to be a bit more careful with your hardware. None of us would like to see your card ruined.
yah thnxs for the heads up
u think this is a good OC?
also which game is more demanding on which i can try ?
Crysis
Stick with it, I can only get 720/1440/1107 stable in ATI Tool, 3DMark06, 3D Vantage, Crysis, GTA IV, 4 hours in FurMark for 4-5 hours at a time, so I'd say that would be stable.
I can run 3DMark 06, and Vantage and ATI Tool at speeds of 744 Mhz, 1512, and 1150 and have no problems. I've never went over 744 Mhz on the core. and I can run 1544 on the Shaders but it doesn't like it very much.
As far as gaming. Most games I cannot run those though. Most games I'm able to play stable with 720/1512, 1150, but Games like Crysis, FarCry2, and Warhead I can't play Stable with anything over 680 Mhz Core and 1466 Shaders.. not sure. I know crysis is the most demanding game around. and it gives it a workout. so I usually just stay around default for regular use, and eVGA precision loads on startup and I run with my fan set to 61% (Wont run at 60%). then I close it. I then have a few profiles set up. One is default speeds with the high fan speed. one is the eVGA FTW edition speeds of 666 and so on. and then I have a third that runs this. 680/1466/1120 for regular and most gaming. I sometimes go higher on like COD4, but I don't really need to with SLI.
you got a good card, enjoy it. and don't hurt it by running ATI tool for 7 hour unattended..
yah i wont run like that again
iam was a noob at this
but really guys after ur help i think my card has actaully made the games look much more crisp and much shinier
ok played nba 2k9,gta 4(damn not much increase in fps but still),burnout paradise
played these 3 games and i have to say that the card is one of the best at Ocing
any more advices?
also i wont oc more than this and i dont play crysis much so i wont play with this but is it like a rule to actually test it with crysis?
UPDATE
guys just played crysis warhead at the same settings
730/1460/1150 for about 20 15 min or so and no problems watsoever
now shld i play more to test the card or u think that my card is now stable?
the game was very responsive and the effects were much clear and crisp
i also think i gained some fps also not sure by how much mayb 5-10
1 - 19 of 19 Posts
