i decided finally on my parts and i feel comfortable with putting it together now
i bought a fan controller and a new case a new psu
a new mobo and new ram to complete my OC and now i need proper cooling
my color scheme is earth colors simply because thats what the boards colors are so my sleeving is going to be as such. hopefully the tube for the watercool setup can be as well (have not seen any that fit this color scheme yet)
http://www.frozencpu.com/products/11...HOT.html#blank
is the kit im looking at as suggested by others
now i need tubing and i need earth colors if possible
and i wish to know if the pump is strong enough for my liking
it must support 2 gpu and a cpu which i dont know how to tell if the pumps able to do such. im also partial to the T virus res and so this res is not what id like
also for tightening the tube are the plastic or metal clips prefered? seems to me the metal ones allow for a better tight fit
again im supremely confident i can build it if i only knew what to build...
i would need help picking out EVERY little part
edit - new parts are in sig
