1 - 3 of 3 Posts
I bought this memory to overclock with but I dont seem to be having very much luck with it so far. Does anyone have any ideas?<br><a href="http://assets.overclock.net.s3.amazonaws.com/1/17/1701291e_vbattach32802.jpeg"><img alt="LL" src="http://cdn.overclock.net/1/17/525x525px-LL-1701291e_vbattach32802.jpeg" style="width:525px;height:394px;"></a>
Could you get us a shot of your memory tab?<br><br>
Just so you know, the HZ is popular because it can usually get speeds up to about 270-290 mhz. If you want to take advantage of this, you'll have to drop your multi down, and run your CPU at 270-290 HTT, depending on what your HZ and/or CPU can do.
Overclock Failed...
<tr>
<div>
Originally Posted by <strong>Sauce73</strong>
</div>
<div style="font-style:italic">I bought this memory to overclock with but I dont seem to be having very much luck with it so far. Does anyone have any ideas?</div>
</td>
</tr>
</table>
</div>Since you're posting the SPD timings of your memory (which has nothing to do with how fast it is running), may I sugget that you start here:<br />
<a href="http://amd64oc.blogspot.com/" target="_blank">http://amd64oc.blogspot.com/</a><br />
<a href="http://www.anandtech.com/memory/showdoc.aspx?i=2223&p=5" target="_blank">http://www.anandtech.com/memory/showdoc.aspx?i=2223&p=5</a>
1 - 3 of 3 Posts
