1 - 16 of 16 Posts
Hey new to the forum but not to overclocking, i recently overclocked my 6200 (nv44) from the stock too 405/core 300/mem (600mhz) doesnt look like the settings took i did the bios edit with nibitor bios updated no prob went back into vista updated my experience index and i went from a 3.2 to a 2.4 please help.
system specs
Windows Vista Ultimate
Nvidia 158.** Drivers
Geforce 6200 AGP 8x 128mb ram (nv44)
Yeah made sure clock was stable ran it fun with atitools before adjusting the bios, no artifacts when i restarted the system i check rivatuner and it says im running at 200/core and 400/mem i dont understand it i flashed the bios back and still says the same?
my friend has that card he was lucky to get 10-25 mhz overclock
but have you tried flashing the original bois back
he said he did flash it back.
I'm thinking your bios is srewed up....
not yet im going to though, i was reading up on vista ultimate and it says that most of aero and other gui functions are done in 2D so i changed the core to 405 for 2d and 540 mem, if that fails i will restore the original bios but i have the funny feeling that my experince index wont go back up too 3.2 with out a fresh install
or a fresh card (possibly)
Discussion Starter · #12 ·
yeah well unfortunely thats not an option right now its working just not where i wanted it to be after an overclock, and i was hoping that one of you guys could help me figure this out
Well Unfortunatly thats a risk with overclocking.
It will sometimes damage it.
Try getting a Non-modded BIOS and flashing it to that card
Power Squid
For some reason, when I flashed my 8800GTS cards so I could run overclocked in Vista, I had to reinstall my graphics card drivers again as the operating system thought I had installed a new card. I suggest you try reinstalling your drivers too just incase this is the issue.
Discussion Starter · #15 ·
Figured it out apprently flashing the bios and the drivers i had installed together with vista's new way of handling drivers had my card running at half the speed i uninstalled the drivers flashed my bios back and it worked but i didnt stop there uninstalled the drivers agian then flashed my bios again 405/core and 600/mem went from a 3.0 vista rating (the lowest was graphics for business and gaming)to a 3.5 was my lowest building a new system just wanted to see what tweaks i could do to improve that experinece index that thing is like freaking credit for computers the lower the score the horrible the system
Thanks for all you guys help i really appericate it you guys responded quick with the help i like that teamwork
Thanks
Power Squid
Thanks
Nice to see you got it working.
1 - 16 of 16 Posts
