Need help before completing my build..
321 8
Ok so so basically I need like a check list of software I will have to get for when my rig is done. Some of my questions here are definitely about benchmark programs but I also have some questions about backing up data.
Let me start off with:
What programs should I get for benchmarking and OCing?
So far I have gotten CoreTemp, CPU-Z, HDTune, RivaTuner and 3DMark06 & Vantage (didn't know if I needed just one of them or not).
What are the best programs/apps to monitor temps and CPU usage?
Something useful on my desktop or during gaming? It'll be for Vista 64.
Now I have some questions about HDs and backup:
While using Raid0, if one drive fails, the other drive is still usable correct?
I'm aware that in raid0, if a drive fails you lose all your data. Which brings me to my next question.
Is there a way to backup OS/OS settings to a CD or could I just use my WD external HD to backup OS and programs? If so, what format does the external have to be in?
Currently my ext drive is in FAT32. Do I need it in NTFS? How do I change it?
Is there a certain program that I could use to make it easier to backup important info/files, or do I just burn everything to a CD?
Will I be able to backup games from Steam onto a CD and later reinstall them or just download the game again from the site? (sorry never used Steam before)
Any help will be appreciated.
1 - 9 of 9 Posts
So far I have gotten HDTune, RivaTuner and 3DMark03,05,06 (didn't know if I needed just one of them or not).
Get Orthos for CPU testing and Memtest for the memory
Not sure about this one but I use Coretemp for my q6600. I am not sure what the best is for the I7
If 1 drive fails in a RAID0 setup then your RAID is dead. You can format the still good drive and use it as a stand alone drive but all info on the drive from the array will be gone.
Backing up an OS is pointless imo. reinstalling an OS is not that hard and it will give you a fresh install to work with. It is a better idea to backup your important stuff like music, important docs or anything you don't want to lose. BUT if you really want to backup your entire HDD then you could just make an image of the drive with Norton Ghost or a similar program after you get all your drivers and programs installed.
No need to change the file system of your thumb drive.
See above answer
You can re-download steam games when you get the steam app reloaded.
I hope this helps some
So basically just replace the dead drive, and then I can go ahead an redo the raid0 setup?
Thanks for the help.
Yes, you can replace the dead drive and then create your new array.
Intel Burn Test/Prime95/OCCT/Memtest for your OC stability testing.
SiSandra isn't too terribly bad either for system info.
Get 3dMark Vantage in addition to the previous versions you have listed. Super-Pi is another benchmark I would recommend.
Since you're using the X58, download the EVGA E-Leet and precision programs.
GPU-Z, realtemp or Coretemp should be helpful as well.
Discussion Starter · #9 ·
Originally Posted by SDawg View Post
What warnings are you seeing and from what programs?
Well, before downloading the programs it always has a warning you have to agree with before downloading. I have seen them in several sites I went to download most of these programs. Mainly the stress test programs (like Prime95, Intel Burn Test, etc..).
1 - 9 of 9 Posts
