1 - 5 of 5 Posts
My Motherboard runs sluggish.
I Only suspect because i have it all on default setings
If anyone knows any tutorials for settings or any suggestions would be any help im on stock cooler
temps usually run around 45-50 degrees at load
heres my specs
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-990FXA-UD5 REV 3.1
BIOS: FB
Processor: AMD FX(tm)-6300 Six-Core Processor (6 CPUs), ~3.5GHz
Memory: 16384MB RAM GSKILL pc312800 F3-12800CL9-4GBXM
Not new to Overclock.net
What do you mean by "sluggish"? What exactly is slow?
slow in games the fps isnt running ta par usually runs like 30 fps it kicks up but only momentarily
That's typically something that can't be fixed by changing any settings in the BIOS. That's likely something else - but what, I don't know.
1 - 5 of 5 Posts
