Hey there guys and gals,
First time posting but been a long time reader of the forums (although I just recently started an account)
I am hoping you guys can help me out with my mostly gaming PC build. I do some Photoshop work, I'm an amateur at best, but am learning it rather quickly. I also plan to learn some Java, C, C++, etc coding within the next few months before college starts up again.
I haven't built a PC in about two years and my last build was a $600 budget build(big mistake) and this time I plan to go all out. My Asus G53 gaming laptop has done me well but time for a new desktop.
I have done a lot of reading and so far this is what I have come up with:
Windows 7 Ultimate - Already have
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 --- I have already purchased this from my local Micro Center for $200
HDD - I have a Hitachi Deskstar 1TB drive from my previous build that I will be using.
Ram - http://www.newegg.com/Product/Product.aspx?Item=N82E16820233190 --- I purchased this ram about six months ago on sale for $35. This might be a bottleneck later, but Ill hold onto it for now.
Power Supply - I have an Antec 750w power supply from my old build that I would like to use. I might upgrade later for an SLI config.
Motherboard - Asus Maximus V Formula --- I have been waiting for this board since last month and it seems like it might be released sometime in early June according to this post.
Here is my question though. I do plan to OC my CPU to (hopefully) as close to 5ghz as possible, so should I wait for Maximus V board or should I go with the Sabertooth? If the Maximus V goes upwards of $300 I might lean more towards the Sabertooth. I read a lot of great things about the Maximus IV boards, any input would be nice.
GPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16814125423 or http://www.asus.com/Graphics_Cards/NVIDIA_Series/GTX670DC2T2GD5/ or http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787 -- Atm I am leaning toward the Asus GTX 670 DirectCU II when it is released but I do need some input on this. I have been debating on whether I should get the Asus when it hits or if I should wait for an EVGA 4G card. I have read a lot about vram issues but it isn't conclusive at all. Half the people say you don't need more than 2GB of vram and the other half says you do need more. I game on a 24" 1080p monitor and would like the highest settings possible in games such as BF3, Arma II DayZ mod, Skyrim (with a lot of high texture packs, not just the official HD pack from Bethesda), Batman Arkham City, and so forth. What do you guys think I should do?
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225 --- This seems to be the top contender for me. I plan to try some water cooling on this build and have read that this case can support a 360 rad up top in either push or pull config and a 240 rad at the bottom with some modding. Can anyone else suggest maybe a better case, if there is one?
WC kit - http://www.frozencpu.com/products/14183/ex-wat-182/XSPC_Rasa_750_RX360_Universal_CPU_Triple_Radiator_Water_Cooling_Kit_w_RX360_Radiator_and_Free_Kill_Coil.html?tl=g30c321s1310 or http://www.frozencpu.com/products/12222/ex-wat-162/XSPC_Rasa_750_RS360_Universal_CPU_Triple_Radiator_Water_Cooling_Kit_w_Free_Kill_Coil.html?tl=g30c321s1310
This will be my first plunge into water cooling and have done some major reading on it, but I really can't tell what the major difference between these kits are? Is the RX worth the extra $40?
CPU $200 + Maximus V (assuming a $350 price) + GPU (assuming a $450 for the 4GB) + case $200 + WC Kit (assuming RX $189) = $1389
or
CPU $200 + Sabertooth $239 + GPU (assuming $450 for 4GB) + case $200 + WC Kit (assuming RX $189) = $1278
I would like to save as much money as possible but without going to cheapy on it. I can of course go with the lower priced GPU and WC kit, but I would like as much input as possible.
or
