I am looking to build 3-4 office pcs sub $400 each. I want to get 2-3 life out of them. Heres what I got so far. I would really enjoy an MINI-ITX Case,
Main Components (CPU + Motherboard + RAM)
Intel Pentium G3220 Dual Core 3.0GHZ Processor LGA1150 Haswell 3MB Cache Retail Haswell ASUS H81M-A uATX LGA1150 H81 DDR3 1PCI-E16 2PCI-E1 SATA3 USB3.0 HDMI Motherboard*
Kingston HyperX Black KHX16C9B1B/4 4GB DDR3-1600 CL9 DIMM Single Memory Module x2 for 8GB DDR3
Cases
Antec VSK-3000E MINI-TOWER mATX Case Black 2X5.25 1X3.5 EXT 2X3.5 USB3.0 Rear 92MM Fan No PSU + Seasonic SS-350ET 350W ATX12V 20/24PIN ATX Power Supply Active PFC 80PLUS 120mm Fan OEM*
or
Thermaltake V2 Plus ATX Mid Tower Case Black 3X5.25 6X3.5INT USB3.0 w/ 450W Power Supply
SSD
Crucial M500 CT120M500SSD1 2.5in 120GB SATA3 6BPS 7MM Internal Solid State Drive (SSD)
What do you guys suggest, is the Intel Haswell cpu a good choice, or should I look amd? Also i'd like an MINI-ITX case to use an MINI-ITX board and no need for 5.25 or 3.25 spaces. I would use an SSD or an ssd on the systemboard. Im cheap and need really cheap builds.
For my ITX Selection
ASUS H81I-PLUS/CSM LGA1150 Mini ITX 2XSATA 6GB/S 2XSATA 3GB/S 1xPCIe16 Dual Channel Motherboard
8GB DDR3
Cant find a good case/PSU for this?
Cases
or
SSD
8GB DDR3
