need help buying ram
336 Views 3 Replies 4 Participants Last post by  13 3 @ 7 l 3 13 0 y
im buying corsair value select(cause im cheap)
i ordered the ---> VS1GBKIT400C3 but it doesnt fit on my mobo
http://www.cyberpowersystem.com/spec...%2C%267.1Audio mother board
im looking for (2x512mb) 1gig of ram
1 - 4 of 4 Posts
it should fit .. try turning it around it only goes in one way look for the notch
that RAM should fit, try what thewaxshop suggested. just don't force the RAM into your board whatever you do.
on a side note you should have gotten the other corsair value select DDR400. they have 2 versions, one is a CAS 3 and the other 2.5 you got the cas3 stuff which isn't as good as the 2.5 stuff... plus, the 2.5 is generally cheaper as seen here:
cas 2.5
http://www.newegg.com/Product/Produc...82E16820145440
cas 3.0
http://www.newegg.com/Product/Produc...P=OTC-d3alt1me
theres somone here selling RAM 2x512 right now for $60
1 - 4 of 4 Posts
