1 - 3 of 3 Posts
I'd like to put together an mATX build (due to space constraints) with an i7-6700k. I probably won't be overclocking, but I want to get a Z170 board in case I decide to overclock in the future. Even then, I would only overclock moderately since I want to keep the noise and heat levels low. I will only use a single GPU, so SLI/Crossfire don't matter to me. I prefer Intel LAN, but it's not a must.
Looking at the mATX Z170 boards available, they seem to have lower VRM phase counts compared to their ATX counterparts (which I perceive as an indicator of quality). Considering that I won't be doing any extreme overclocking, is this something that should concern me, in terms of reliability, stability, and longevity?
The only mATX board I can find with a 10-phase VRM is the ASUS ROG MAXIMUS VIII GENE: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813132569
The rest, from what I can tell, all have 4+2+1 phase designs:
ASUS Z170M-PLUS: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813132573
ASRock Z170M Extreme4: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157675
SUPERMICRO SuperO MBD-C7Z170-M-O: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813182978
GIGABYTE G1 Gaming GA-Z170MX-Gaming 5: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128844
GIGABYTE GA-Z170M-D3H: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128845
(PCI slots? Somebody please remind Gigabyte which decade we're in...)
MSI Z170M MORTAR: http://www.newegg.ca/Product/Product.aspx?Item=9SIA9H53VM6435
(The M.2 slot in this one isn't full-sized, making it sort of useless)
Am I correct in thinking that the Asus ROG could be a waste of money if I'm not going to overclock? It looks like there's a lot of people on here who are knowledgeable about motherboard design and the quality of the various chips/components that are used. So I would appreciate any advice that you would be able to give, on which Z170 board would work best for me!
Pretty much spot on with the ASUS ROG. If your not planning to do much heavy overclocking, just look for a quality / feature rich board at the best price.
If you don't plan to overclock that much I wouldn't give much importance on VRM's. As long its a quality board should have more than plenty, only if you plan to overclock you might need a bit more quality juice.
The Z170M- PLUS and EXTREME 4 are my picks. ASrock makes great small form boards, besides amazing full ATX overclockers boards like OC Forumula series.
I'm also looking for m-atx Z170 but i need as much cpu speed as possible for 144Hz gaming- how much difference would Gene make when overclocking ?
For the moment prices for them in Poland are:
Z170M Extreme 4 - 575 PLN
Gene - 870 PLN (free Doom coupon included)
1 - 3 of 3 Posts
