need help chossing a psu
272 Views 6 Replies 5 Participants Last post by  warsong
here is my planned rig:
I7 920 with mild overclock 3.2-4 ish
ex58-ud3r motherboard
6 gbs g.skill ddr3 1600 going for 8 gbs
4850x2 gpu
monsoon 3 lt cpu cooler
1 500gb hd
1 dvd drive
xclio windtunnel advance case
would a 700 watt psu be enough to pwer this rig? if so i would be greatful if you could recommend one.
1 - 7 of 7 Posts
Here, use this to determine the wattage you need:
http://www.extreme.outervision.com/p...ulatorlite.jsp
Brands such as ThermalTake (ToughPower line), Corsair, Seasonic, Antec, PP&C and Enermax are all good.
i think i found a good one:
http://www.newegg.com/Product/Produc...82E16817341011
its gonna make my pc look like a baboon
, but it should work.
a fine choice indeed
this doent related to the psu..well in a way it does, cause i'd have to up the size of the psu. I was thinking of using this rig for 2d/3d artwork as well as gaming. would i be overkill to add another 4850x2
1 - 7 of 7 Posts
