1 - 3 of 3 Posts
my uncle, his speaker plug broke on his laptop and now when he took the speaker plug out thers no sound on his laptop... is it possible his mb sound is mess up or damage.
Ok, so the metal part of the plug snapped and was stuck in the connector.. correct? Then he was able to get it out, but still no sound.<br />
<br />
First, the silly things:<br />
1) sound is turned on?<br />
2) there is no part of that metal part left in the connector?<br />
<br />
If that's all fine, then I suspect that when trying to remove the plug, some damage has occured to that connector, and that the mobo still "thinks" that there is a external speaker set plugged in. Do you have spare speakers to try?
My only suggestion goes to setting another speaker plug in and "twisting" it a bit in the plug and putting it out again.
1 - 3 of 3 Posts
