Originally Posted by Chipp The only thing I can think of is that they partitioned it at the factory into a 70 and a 130. That's wierd. |
Originally Posted by Sper Okej i got my WD Sata driver and im in the installation for win xp. and it says its 130g when its 200..whats upp whitt that? |
Originally Posted by mfillpot There are restrictions on HDD sizes which patches in XP SP1 fix, the 130GB is a restriction, it does look like the factory went ahead and partitioned it with a pre SP1 system which restricted it to 130GB, go ahead and make a second partition for the additional 70GB of unallocated space. |
Originally Posted by Sper hm okej so install Win on teh 130 then and the 70gig well...save some crap on it...got a 120 gig IDE disk.....but it keeps booting from it even if i out it on slave |
Originally Posted by Bindusar I just went through the same thing. I ended up leaving XP format the drive with the 130gb and then went back afterward through control panel/admin tools/computer management/storage/disk management, clicked on unused space and formatted the remaining space as another drive. |
Originally Posted by mfillpot Let me guide you... What HDDs do you have installed? how many partitions on each disk? how big are the partitions? What partition on what disk is Windows installed on? |
Originally Posted by Sper 200gig Sata driver Nothing installed 120gig ide drive whit windows xp and another partion whit programs on i disconnected the ide driver for now till win xp is installed on the sata |
Originally Posted by mfillpot Do you plan on loosing all data on the disks and reformating and reinstalling the OS? |
Originally Posted by Sper Gonna have OS on sata driver and the ide driver is a disk for saving movies etc |
Originally Posted by mfillpot Who are the manufacturers of the disks? |
Originally Posted by Sper Western digital sata disk and IBM hitachi deskstar 120 gig =P |
Originally Posted by mfillpot You will want the disk wizard that came with the Western digital, load that disk on boot, and reformat both drives, then use the disk to make the partitions fill both disks, remember that the 120GB ide is to be formatted at the boot partition. then reboot the computer and reinstall WInXP. |
Originally Posted by Sper how do i make so the IDE disk doestn boot the OS thats on it? so i can format it in windows |
Originally Posted by mfillpot Like I said, use the disk wizard disk at boot and reformat both harddrives, then you will have no OS on either and will be able to install WIn on the SATA. |
Originally Posted by Sper do i need to install drivers i windows for the hardrive? |
