Hmm...kind of difficult to get a "good" laptop with that budget but:
(I know it's a bit over budget)
http://www.newegg.com/Product/Produc...82E16834220637
or
(a bit more near your budget)
http://www.newegg.com/Product/Produc...82E16834200027
If all else fails you can try dell.com and see what you can get. If you go that route, for your price range, I would suggest a vostro of some sort.
GL Bro!
or
GL Bro!
