Hi there, I got this cheap gaming mouse from E-blue and I like it so far. However, the product did not come with any drivers and there doesn't seem to be any drivers on the manufacturers website.
http://www.e-blue.jp/2011/individual%20product/cobra%20type-m.html
http://www.amazon.com/E-3lue-EMS131BK-Precision-Control-Counterfeit/dp/B005CPGHAA/ref=sr_1_1?ie=UTF8&qid=1375296466&sr=8-1&keywords=e-blue+cobra
I tried searching around on the web and I am having trouble finding it. The reason i need the drivers is that on Win 7 it seems the mouse's forward and back buttons are switched. Also, is there a manual way to switch these buttons without additional software in windows?
edit:
I found the drivers here:
http://www.e-blue.jp/2011/dowmload.html
However, it seems no matter what is set it to, the mouse 4 and 5 buttons are still switched even when trying to change what they do in the drivers. Any help is appreciated.
edit 2:
I fixed it! Problem solved
. I had to go get a different program called "X Mouse Button Control" then manually set the buttons.
http://www.highrez.co.uk/downloads/XMouseButtonControl.htm
edit:
edit 2:
