Need Help Finding Micro ATX Mobo. with 2 PCI-E slots
1256 Views 15 Replies 6 Participants Last post by  Kvjavs
Hello, sorry to bother you all but I could use some assistance in locating a motherboard for my new computer.
I am looking for a motherboard that is Micro ATX Form factor, and has 2 PCI-E Slots for Crossfire and socket AM3, but AM2/AM2+ could work if dual cores are still great for gaming, I dont have a clear answer most of the times. I know Quad Cores are great but is it a giant leap in the gaming area.
This is the motherboard that I am currently interested in, but I am wondering if there are others elsewhere that are good quality and maybe a little bit cheaper.
http://www.newegg.com/Product/Produc...82E16813136068
Also, I know you guys probably get this a ton, and I'm still new here so I'll get to searching, but for gaming could I save a few bucks and get a nice dual core as opposed to a quadcore and still get great performance? I currently have an AMD Phenom II X4 955 Black Edition, but I am working on selling this computer (to build my next one, of course
) I feel like I spent a lil too much getting this Phenom and could have just stuck with my previous CPU or another good dual core (my previous one was an AM2 Athlon 64 X2 4600+)
1 - 16 of 16 Posts
Yes it has 2 pci-e slot for CF at x8 not x16. And yes on the dual get PhenomII x2.
I noticed that
Is there any board that has x16/x16?
I'd stay stick to the quad core, I myself haven't personally worked with dual cores much but I know the second I boot up a single core computer I'm missing my Phenom II. A dual core may play a game alright but you could get stuck fighting for cpu usage like say, listening to your iPod as you play instead of using WMP. I was in that situation and it was bad, sure the games are fine but I like to alt-tab around, surf the web mid-game or chat it up on msn, have my vent not lag terribly. More cores, more multi-tasking, less wait.
Originally Posted by Kvjavs
I noticed that
No.
The performance isnt worth worrying about.
I noticed that
Not for Micro ATX board. For CF you can CF like 2 5770 just fine at x8.
Ok, thank you Markisa, Master Chief & dixson. i was also curious if my power supply (Corsair 750hx) would be able to handle 2 Vapor-X 4890's in crossfire, if anybody might know.
Yes it can. 600 Watt and four 6-pin connectors for CF 4890.
IT can handle 3..
Awesome. Thank you very much all of you.
Are there any other motherboards anybody would recommend?
Any in DDR2 ram standard with 2 PCI-E Slots for Crossfire?
I just built a quad system with this DFI mobo. I am going to add a 5970 and a fermi card later on.
If you get it make sure you get a high wattage psu, the board needs 300W by itself to run.
Also it does not like 1600Mhz Ram very well, I got my 1600 Mhz mushkin to run at 1395Mhz with tighter settings and it is just as good if not better this way.
Managed to overclock 965 C3 to 4.1 ghz 1.55V and CPU-NB 2.7GHZ 1.3875V 1hour linpack stable.
Has good audio and good network chips. Get it it is really good but a little sensitive with the settings you use it with. Make sure you enable ACPI XSDT if you are using a 64 bit system or it will do all kinds of strange things.
Hope this helps, anoobilis
edit: you dont care about the 8x/8x crossfire, get crossfire-on-a-pcb like the amd 5970 or 5950 and use the other PCIe slot for something else, i believe they both run at 16x single mode - there are no other AM3 matx boards with 2 pcie slots out there, only some lower quiality ones but am2+
I'm pretty sure my PSU will be more than enough to power it. Also, I am looking at this now instead. Only because I don't see a huge NEED to upgrade to DDR3, and I already got 8gb of DDR2.
http://www.newegg.com/Product/Produc...82E16813136056
I think that 8GB of DDR2 will hold me off for a while to save up for either DDR3, or switching to Intel (Not that I want to do, but there's just not many mATX AM3 boards with Crossfire, at least that I can find).
Crap, that mobo i was looking at got deactivated. =/
it works for me???
the DFI one, right?
Yeah it's deactivated now, the DDR2 version. I already got 8gb of DDR2 so I'd rather not spend the money and switch to DDR3, not until I can get some bids for my current system.
Sorry to bump this up again, but I am still looking for motherboards. Besides the reviews on Newegg, has anybody else heard or experienced this Jetway board?
http://www.newegg.com/Product/Produc...82E16813153142
Working on a tight budget, wondering if I should get this or just spend the extra money and get the DFI:
http://www.ewiz.com/detail.php?p=MB-...f3012e469785c3
1 - 16 of 16 Posts
