1 - 8 of 8 Posts
Hey there OCN!
I recently received a 9800 GX2 that wouldn't POST. It had absolutely no indication of life whatsoever. Doing what I learned here, I chucked it into the oven @ 350F for 10 minutes. When I brought it back out, the fans spun up and LEDs lit up, but no video output. I then threw it back in the oven, this time @ 380F for 10 minutes, but same results. I then tried OpenYourEye's self-bake technique, but still no change.
Unfortunately, I am not the first owner so I cannot RMA the card, so does anyone have any ideas on how to get this thing working?
The temp is incredibly low solder doesnt melt at 150F
try 300F
Solder is a fusible metal alloy with a melting point or melting range of 90 to 450 degree Celsius (190 to 840 °F)
From wikipedia
Ummm.. That sounds really freaking dangerous. While I wouldn't want to bake it more than like five times, I wouldn't jump all the way up to 300F, perhaps 250F or maybe 275F. Just sounds really risky.
Messed up my temps, it was at 350F and 380F, respectively. Changing OP.
Honestly, if the self-bake method and the oven-bake method don't work; and you know you did both properly. There is extremely little chance anything else can be done to fix it. At this point, just try the oven-fix method one last time and if it's no good then don't waste your time on it anymore.
Discussion Starter · #8 ·
Originally Posted by Somenamehere
Maybe keep it in longer ? 20 min perhaps
Will do
I'm trying to get my computer fixed up right now (new HDD), but will throw it in the oven when I have the chance
1 - 8 of 8 Posts
