1 - 5 of 5 Posts
It seems that computer world changes so fast it's impossible to keep track anymore. I'm in the midst of upgrading my system and so far I only got two components down: 1050t (this was the easiest to choose) and psu corsair hx620 (this took hours of research as there are so many psu's now)
I also spent many days choosing a good mobo (no need for crossfire) and the best I found is GA-890GPA-UD3H. I haven't seen anything significantly better in 150-250$ range. So I'm about to order it.
Now the last thing to choose is ram and there are just too many options.
At least I know I need DDR3 dual channel, since triple channel only works on intels. So I guess no point in 3x2GB, I should simply get 2X2GB.
Now the hard question, what is the best/fastest memory for the system listed above?
I have a few in mind but I'd rather ask for advice so not to overlook something.
Here's what I'm considering:
http://www.newegg.ca/Product/Product...82E16820226132
http://www.newegg.ca/Product/Product...82E16820231277
http://www.newegg.ca/Product/Product...82E16820226123
Any help is appreciated!
*cough*Stock*cough*
the DDR3-2000 sticks are a waste unless you are REALLY pushing the overclock hard, and the mushkin 1600 kit has timings that you can do yourself. Get the Gskill kit and then set the timings and voltages to the tightest values possible without frying the sticks.
Car cheaper than computer
Low timings are more important then speed on AMD chips.
1 - 5 of 5 Posts
