1 - 5 of 5 Posts
Intel E8500
Gigabyte EP45T-DS3R (Bios F4c)
8GB (4x2GB) Kingston HyperX DDR3 1600_9-9-9-24 (#KHX1600C9D3K2/4GX)
The only way I can seem to get truly stable is to run everything at [Auto], which underclocks the RAM to 1333 Mhz at 9-9-9-24 timings. I've tried looking at some of the other E8500/E8600 setups with my motherboard on the forums, but even setting the same BIOS settings as those doesn't work for my rig.
I have run it semi-stable for a long time at 3.8 Ghz (400 x 9.5) CPU, 1280 Mhz 7-7-7-20 for the RAM, but I will still encounter random crashes. Or in the case of Chivalry: Medieval Warfare, constant crashes.
Based on the above, I don't think the CPU is the problem - it seems to be a Mobo/RAM issue. Any help on getting the advertised spec of 1600_9-9-9-24 or anything better than auto-underclock would be much appreciated. I think OC'ing the CPU will be painless after that.
Hello
You should first test the ram on stock CPU Speeds, and see if you get the Ram stable on 9-9-9-24 1600mhz.
The reason for the issue you are having, is that if you up the FSB, the ram speeds raises too.
So it will reach OVER 1600mhz, to counter-act that you have to set a Lower Memory Multiplier.
(Like 1333mhz, but because you OC FSB it will be higher)
You should first find your maximum CPU OC while leaving the memory as low as possible, and run Stability Test software,
after you reach a stable cpu Speed, then you should try tweaking the Ram speeds / timings.
Originally Posted by prescotter View Post
Hello
Sounds like a plan. Forgive my ignorance, but how do I set my BIOS settings to make that happen? It seems to me like I can't run the CPU @ stock speed and also run the RAM at 1600 Mhz 9-9-9-24 with the settings I've tried.
Here is the default BIOS template:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .............: [AUTO]
CPU Clock Ratio .....................: 9 X
Fine CPU Clock Ratio.................: +0.5
CPU Frequency .......................: 3.16 GHZ (333x9.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...............: [ Disabled ]
CPU Host Frequency (Mhz) ............: 333
PCI Express Frequency (Mhz) .........: [AUTO]
C.I.A.2 .............................: [ Disabled ]
Advanced Clock Control [Press Enter]
CPU Clock Drive......................: [ 800 mV ]
PCI Express Clock Drive..............: [ 900mV ]
CPU Clock Skew (ps)..................: [ 0ps ]
MCH Clock Skew (ps)..................: [ 0ps ]
DRAM Performance Control
Performance Enhance..................: [ TURBO ]
(G)MCH Frequency Latch...............: [AUTO]
System Memory Multiplier ............: [AUTO]
Memory Frequency (Mhz) ..............: [AUTO] (1333 Mhz)
DRAM Timing Selectable ..............: [AUTO]
Standard Timing Control
CAS Latency Time.....................: 9 [AUTO]
tRCD ................................: 9 [AUTO]
tRP'.................................: 9 [AUTO]
tRAS.................................: 27 [AUTO]
Advanced Timing Control
tRRD.................................: [AUTO]
tWTR.................................: [AUTO]
tWR..................................: [AUTO]
tRFC.................................: [AUTO]
tRTP.................................: [AUTO]
Command Rate (CMD) ..................: 0 [AUTO]
Channel A
Static tRead Value...................: [AUTO]
tRD Phase0 Adjustment................: 0 [ AUTO ]
tRD Phase1 Adjustment................: 0 [ AUTO ]
tRD Phase2 Adjustment ...............: 0 [ AUTO ]
tRD Phase3 Adjustment................: 0 [ AUTO ]
Trd2rd(Different Rank)...............: [ AUTO ]
Twr2wr(Different Rank)...............: [ AUTO ]
Twr2rd(Different Rank)...............: [ AUTO ]
Trd2wr(Same/Diff Rank)...............: [ AUTO ]
Channel B
Motherboard Voltage Control
Voltage Type...............
CPU Vcore............................: [AUTO]
CPU Termination….....................: [AUTO]
CPU PLL..............................: [AUTO]
CPU Reference..........................: 0.760V [ AUTO ]
MCH/ICH
MCH Core.............................: [AUTO]
MCH Reference........................: [AUTO]
MCH/DRAM Ref.........................: 0.750V [ AUTO ]
ICH I/O......................….......: [AUTO]
DRAM
DRAM Voltage ........................: [AUTO]
DRAM Termination ....................: 0.750V [ AUTO ]
Ch-A DATA VRef.......................: 0.750V [ AUTO ]
Ch-B DATA VRef.......................: 0.750V [ AUTO ]
Ch-A Address VRef....................: 0.750V [ AUTO ]
Ch-B Address VRef....................: 0.750V [ AUTO ]
Advanced Settings
Limit CPUID Max. to 3...............: [ DISABLED ]
No-Execute Memory Protect...........: [ ENABLED ]
Load-Line Calibration...............: [ DISABLED ]
CPU Enhanced Halt (C1E).............: [ DISABLED ]
CPU Thermal Monitor 2(TM2) .........: [ ENABLED ]
CPU EIST Function...................: [ DISABLED ]
Virtualization Technology...........: [ ENABLED ]
USB Legacy Support..................: [ ENABLED ]
Well, after some tinkering, I've arrived at a configuration will run Prime95 for 10+ hours before I interrupt it:
E8500 @ 3562.5 Mhz (375 x 9.5)
8GB RAM @ 1200 Mhz, 6-7-7-19 timings (FSB:RAM 5:8, 600 Mhz x 2)
Should I still try to get the rated 1600 MHz 9-9-9-24 out of it? Looking for any and all advice on improvement.
Here are my settings:
CPU Frequency .......................: 3.562 GHz (375x9.5)
Clock Chip Control
CPU Host Clock Control...............: [ Enabled ]
CPU Host Frequency (Mhz) ............: 375
Performance Enhance..................: [ STANDARD ]
System Memory Multiplier ............: [3.20B]
Memory Frequency (Mhz) ..............: 1200 Mhz
DRAM Timing Selectable ..............: [MANUAL]
CAS Latency Time.....................: 6
tRCD ................................: 7
tRP'.................................: 7
tRAS.................................: 19
Channel A
Channel B
CPU Vcore............................: 1.300V
CPU Reference..........................: [ AUTO ]
MCH/ICH
MCH/DRAM Ref.........................: [ AUTO ]
DRAM
Advanced Settings
1 - 5 of 5 Posts
