1 - 3 of 3 Posts
So after much testing i know i can get 4.4ghz everything on auto with 1.3v in bios....1.272v (CPU-Z)..... but at first i tested 4.5ghz did prime 95 for 11-12hrs and BF3 for hours (i find BF3 is really a good quick test if your OC is not stable it WILL crash quick)....
- 4.5ghz everything auto with 1.35v in bios (which worked before tested)
since i have been testing to go higher 4.6ghz mostly, and 4.7-4.8ghz since those failed i decided to go back to 4.5ghz and now it wont be stable even with higher voltages...
Can anyone help me??????
Originally Posted by solar0987 View Post
Reset cmos
try again with oc
did that it worked also before now seems not anymore
1 - 3 of 3 Posts
