1 - 7 of 7 Posts
When you say mid tower are you looking for the smallest case possible or just a normal mid size case?
There are a number of cases that will work -anything with top 360 compability and a 120mm exhaust should work.
Goodbye
That will fit just fine in an S340 Elite. I use one with a 115i and there's a 120/140mm fan slot at the top of the case that would work well.
Discussion Starter #4
Yeah a mid size ATX case. Sorry if my wording wasnt very clear..also no price limit here I'd love something beautiful
RGB Rainbow Vomit!
Personally I'd mount the 1080 radiator at the rear and a quiet/slow 140 at the top. A 120 in the top looks out of place on my S340.
Other than that its a fine choice with plenty of space and mounting options, and can easily accommodate four SSD's.
1 - 7 of 7 Posts
