I just order a 4gb kit (2x2) of g.skill PI 1066mhz memory and not sure what the problem is. I originally had 4x1gb of g.skill HZ 800mhz memory and was able to OC to 1081mhz at 2.3v. I was starting to get concerned at the fact that I had to over volt by .2 and read that a lot people's modules were dying quick because of the over voltage. I ordered the PI's because they ran pretty much what I had my HZ's at but at stock voltage. The problem is now my OC is no longer stable. The PI's are technically only overclocked by 15mhz to 1081 but cannot get orthos to run stable past 3 hours. When I check cpu-z, it shows that the part number for my the PI's is pc2-8500 but above that it shows as ddr2 800. Is this because the mem divider I run is ddr2 800?
Running memtest86+ now and about a half hour into it with no errors but even there is shows dimm 1 and 3 populated with ddr2 800. So frustrated right now and not sure what to do...
