go to the bios where it says Chipset config.. something like that...
Then the first option is something about RAM... its enabled... so disable it... and then you can configure the RAM timings...
i just did that 3 minutes ago... im fine
i guess...
I would also recomand not to raise your vcore for now... let it [auto]
And...
Overclocking just for fun isn't realy wise... please download speedfan to monitor your temps..
One more thing... if you can't run a game at 3.0Ghz... its the PSU... (2oow)..
kinda low for overclocking...
And...
