Ok, well I feel that my BIOS is lacking as I haven't much of an idea on how to set it up properly, and I was hoping someone more experienced with tweaking BIOS and this motherboard in general can help me out here. My Vista Home Premium install seems to take FOREVER to load, and is really laggy once it does boot. I'm hoping with some BIOS tweaks I can decrease my boot time, as well as take some of the lag out of Windows.
I already have the BIOS setup to only boot from the HD, so there is no delay in it trying other devices first, however, my boot times are still astronomical. When my computer first boots there is a long delay between the time the BIOS post ends, and the Windows loading screen appears. Then when the loading screen does come up, it takes 12-15 full sweeps across the little loading bar until the loading screen goes away. Then it'll have another lag before it automatically logs me in to the system. Once the computer is booted up, I still get a lot of lag in the system. Opening menus has a noticable delay, and when I right-click on the desktop there is usually about a 10 second lag while the 'busy' mouse icon appears, before the menu will pop up. Also, popup notifications make the system lag noticeably. I don't have any programs that start up with the system - that includes no Anti-virus software or 3rd party firewalls.
My system:
-MSI K9A2 Platinum V. 1 - Upgraded to newest BIOS for Phenom II support
- Phenom II X4 940 Black Edition. Only overclocked to 3.2Ghz, voltage set to 'Auto' in BIOS, Runs very stable 24/7 @ 100% usage
- 2x1GB OCZ Platinum DDR2 800mhz RAM - I hear this is rated to run between 1.8-2.2v, but when I set it to 2.0v in BIOS, it still doesn't come up as 2.0v in Everest or CPU-z
-Dual 9800GX2's - not running in SLI. Latest GeForce Drivers. Dummy plugs on DVI outputs to make them active for [email protected]
- WD 500GB Cavar Blue - Windows is only thing on disc, but partition only takes up 100GB, rest is unpartitioned
-Nothing else is hooked up to the rig besides a PS/2 keyboard, a USB mouse, LAN ethernet cable, and my monitor
I'm open to any and all suggestions you guys may have! Anything I can disable in the BIOS, or any settings I should keep on... Any advice or tips are greatly appreciated! Thanks in advance!
woody
My system:
woody
