1 - 5 of 5 Posts
Stock is 200x11
I got it to 230x11 stable, temps at 100% load ranging from 51-54 degrees celcius.
Should i keep going to 236 or just stop?'
thanks
I would go as far as you can without raising vcore and then lower it just a couple and stress it. Check out the temps and go from there.
1 - 5 of 5 Posts
