Update your BIOS and try instant 6Ghz if you have it on your motherboard and try that.Thanks for the answer, but I have a gigabyte z790 aorus elite ax and I set the multiplier to 55, avx 0, v cor 1.3v, tvb disable, I run the fpu aida64 test, but the board stubbornly reduces it to 5.3, I don’t know what to enable or disable seems to have tried everything?
post #4 in this thread has and gigabyte z790 aorus elite update information I would assume gigabyte z790 aorus elite ax would have similar instant 6Ghz.
I am not sure why people with gigabyte motherboards are having problems,I would actually have to test one myself. If you tried everything ,then I would exchange the motherboard for a different brand if you can. I can make suggestions all day but like you said you tried them all.
(2) Need Help overclocking 13700k | Overclock.net
SkatterBencher Gigabyte motherboard 4 different overclocking ways to achieve overclock,I suggest read all of it.Good luck
SkatterBencher #49: Intel Core i9-13900K Overclocked to 6100MHz - SkatterBencher
