I dont think you will find much in the lines of bios options on that board.. Go into bios and see if you can adjust the fsb, or freq anywhere.
You will probably have to find some sort of 3rd party program for cpu overclocking. http://www.cpuid.com/clockgen.php clockgen will work, although I would not push it too far, and I wouldnt have it run at start up with the OC setting.
