1 - 5 of 5 Posts
Hi ppl
I have bot MSi GTX 460 Hawk 1GB which is at 780 mhz default.
Plz need settings for overclocking it.
My room temps are 33*c n have an good airflow case with 4 fans.
i want to oveclock it to 900mhz or atleast 880 mhz stable.
thank you
__________________
i7 950 @ stock
CoolerMaster Hyper N620
Asus P6X58DE
Corsiar Dominator 6GB 3x2GB(CMP6GX3M3A1600C8)
WD Caviar 1TB
Corsiar TX750W
XFX 9600GT
Dell ST2320L 23" Monitor
Originally Posted by crazy.wingman;13144327
plz tell how to set custom voltage in afterburner as the option is grayed out.
Under settings there is a checkbox you have to hit. I can't remember what its described as, something about voltages. But you need to enable that to tweak the voltage.
1 - 5 of 5 Posts
