1 - 20 of 20 Posts
Hi guys, I need some help overclocking my AMD 965 BE C3 (as the title says
). I currently have it all on stock, I just got the CPU. I have air cooling, Coolermaster hyper 212 plus. I've overclocked before, not this CPU, but I've never reached 4ghz, and I really want to now. I just want to know how can I get to 4ghz, what volts, what to do with cpu-nb, etc.
system specs:
Motherboard: MSI 790GX-G65
RAM: Gskill Ripjaw 12800 CL9 @1600, 9-9-9-24 @ 1.65V
CPU: AMD 965 BE @3.4, V= Stock (1.43, it's on auto) same with cpunb and HT
Video card: Gigabyte 460 gtx 1gb
Power supply: Powercolor 750W
Any help would be greatly appreciated.
Hi, ive got a similar spec to yours and my voltages are:
Cpu - 1.409V running at 4.01ghz (Multiplier x20, Bus Speed 200) (can increase upto 1.55V but the lower the better - less heat),
Cpu/NB Frequency - 1.18V (up to 1.35 -1.4V but the lower the better) @ 2600mhz.
Keep your HT Link at 2000mhz and up yr cpu/nb to 2600mhz.
Always try with lower voltages 1st (try mine which are LOW) and if it fails to boot add in small amounts of voltages to the cpu. Once into windows run Prime95 Blend test and also run AOD Stress test.
Hi fabiotonic, I run AOD Stress Test for 1 hour before running Prime to indicate any early errors as it picks them up real quick. Prime95 Blend (dont really perfer to) over night and MemTest86+ for 7 passes as thats good enough for me lol and ontop of all that hammer some GAMES lol
Discussion Starter · #6 ·
Ok. Well I'm trying right now just by upping the Multiplier.. and the voltage a tiny bit from stock voltage, so CPU volts are now at 1.43. I haven't messed with the CPU NB yet nor the ram. Ram's at 9-9-9-24 @ 1.65v.
So far I'm at 3.7ghz at 1.43 (only 20 min run on Prime95).. I'm doing a small ffts test since it's more towards CPU than anything. I ran a blend test earlier(more towards RAM) and it ran fine for an hour, no errors. Gonna leave my CPU voltage at 1.43 and keep adding on the Multiplier and run prime95 tests for about an hour each time I UP the Multiplier (@18.5 atm).
Do you suggest messing with the CPU-NB now or just figure how to get to 4ghz first then messing around with it?
Im Just gonna throw this out here, AMD Overdrive, some people don't like this, but it does have its uses. Theres a auto clock feature on it , Will give you a idea what your system can do then you can fine tune it from there , try and find a tutorial for it shouldnt be too hard, just an idea, Have fun thats the whole idea !
heres a link
http://sites.amd.com/us/game/downloads/amd-overdrive/Pages/overview.aspx
Hi, I wouldnt use the autoclock feature as that adjusts the voltages of the cpu, ram, cpu/nb etc (been also advised on many other forums).
Regarding the ops question, only do 1 thing at a time to max each components limit. At the moment your increasing your multiplier, once youve found your highest limit and start blue screening/freezing etc increase the cpu/nb and continue but keeping an eye on your temps and the voltages ive given above. Once youve reached the maximum drop the multiplier back down to stock and start upping your FSB etc. Once you have found your stable clock you then can start messing with your memory timings which il help.
· Cheesebumps!!
Originally Posted by blakmumba;13117296
If your still having problems leme know and il help you as much as I can.
Remember to REP+ me if iv helped as im enjoying this forum lol
begging for rep is not allowed here..
OP: since it's a BE chip you can simply crank the multiplier up to what you desire..with a good cooler you can easily do 4ghz on that chip with 1.45v to 1.5v on vcore..you can either crank the NB up too if you like a boost on performance, given you supply it with adequate voltage..set your memory settings to the specs indicated/rated for it..then do some stressing to see if its fine/stable..watch out for your temps too..
· Premium Member
High voltages... 125W x4.... MSI motherboard.... ruh oh
You cannot 'crank' the multiplier to what you 'desire'. Each processor/motherboard combo caps out at a certain limit which then you start upping the FSB as i explained to the op.
If only it was that 'EASY'
· Cheesebumps!!
its a BE chip..duhhh..crank multi to 20 w/o cranking FSB = 4ghz.. (nobrainer 20x200 math)
he's a beginner give him an easy approach on things..plus that board ughhh..
i won't recommend blasting that off with 1.45v or more..since alot of dying boards came from MSI lately..either way OP this is just a reminder..
do get a good reading on this before you proceed:
-all about choosing the right board
-Motherboard phase list
credit goes to xd 1771
If you read your post and I quote ' since it's a BE chip you can simply crank the multiplier up to what you desire' i dont see you saying up the multiplier to 20. And as he's a beginner, i did give him an easy approach by giving him instructons on whats the best and stable way.
Your not going to say to a new learner driver 'just throttle the gas pedal' are you like what you stated in the quote above 'go all out' DUH. I took my time to explain.
Your quik to do the math to me and explain but in your 1st post I dont see you explaining in such a detail anywhere.....DO YOU
· Cheesebumps!!
Originally Posted by blakmumba;13118236
If you read your post and I quote ' since it's a BE chip you can simply crank the multiplier up to what you desire' i dont see you saying up the multiplier to 20. And as he's a beginner, i did give him an easy approach by giving him instructons on what the best and stable way.
i hoped that the OP will be experimenting first, and not DIVE into it on an instant..why am i explaining to you anyways???
if he was able to catch what was meant in my post..and its true that every board has a different cap for the highest multiplier for CPU..i see your point
duhh you're so great i get it..
Discussion Starter · #17 ·
So far my highest I can get on this chip is 3.9 ghz @ 1.548V... If i go higher on the multiplier I get blue screens. Any suggestions? Haven't messed with anything just the multiplier. Ran prime for 2 hours @ 3.9ghz @ 1.548v and no errors. Load temp= 60c (highest). I can't get any lower than 1.548v to run @3.9ghz.
Listen to him, your motherboard has a 4+1 phase VRM system.
This man knows what he is talking about and has even written a whole useful thread about VRM explosions.
4ghz at 1.4v? That's crazy low, i can only get to 3.8ghz on that voltage, which is stock volts for me.
1 - 20 of 20 Posts
