Hello so I just installed my new XFX Radeon 6950 (I'm so excited to upgrade from my Nvidia GeForce 9400
) and I tried used the sapphire trix tool (http://www.sapphireselectclub.com/ssc/TriXX/TriXX.aspx)
I am wanting to put my core clock at 1050 (currently at 850)
However I ran into a problem. I tried doing this, and then I pressed apply and my screen when white. I tried again and then my screen went kind of gray. I then have to press my reboot button and the settings are back to default. What am I doing wrong, and would it be easier just to do this from the bios?
Also what should I set my GPU Voltage at.
I'm using this for bitcoins and in the notes it says this, maybe you can tell what it says:
Powercolor 6950 @ shadermod on original Bios 6950 / 1000mV 850/730, +20% powertune, Fan @ 60%, -v -w128 -f1.
