Need help picking a CPU
756 Views 4 Replies 4 Participants Last post by  CDub07
My MSI GD70 is here tomorrow as I'm part way though moving from Intel back to AMD ( Go me
Now I have my eyes on a Athlon 2 x4 620 for £77
But it has no L3 cache compared to the Denab core and it's a gameble to try and unlock the L3 cache or do I go and buy a fully fledged Pehon 2 dual core with L3 cache and try and unlock that?
1 - 5 of 5 Posts
Hm.
Well, that depends what you do with your system. Apparently most of the newer Phenom II CPUs don't unlock as well as the older ones, but I can't talk for the Athlons since I don't follow AMD much.
If you're going to be purely gaming, then get the 550 BE. If you're going to be encoding, and doing other things with multi-threaded applications then get the Athlon II X4.
Try not to factor the unlocking process into your decision; I think it's unwise to do so because it's not a certainty.
If budget is an issue, the Athlon X3 435 is just £43 from YoYoTech.
Give us a budget and it would make this question a lot easier mate.
At Stock my Athlon II X4 as far as speed of the cpu felt a little faster than my Athlon X2 7750BE @3.01GHz but not much. It chewed through multitasking but gaming see no difference really. Where the 620 shines is when u overclock it. I believe a have a Deneb based core but can't unlock anything.
1 - 5 of 5 Posts
