Which one?
  • AMD FX-6100 Zambezi 3.3GHz
    Votes: 6 60.0%
  • AMD Phenom II X4 960T Zosma 3.0GHz
    Votes: 4 40.0%
1 - 4 of 4 Posts
My choises are.
1) AMD FX-6100 Zambezi 3.3GHz.
2) AMD Phenom II X4 960T Zosma 3.0GHz.
Well I really only need a quad core but I'll looking to upgrade to windows 8 and the FX chip works better on windows 8. Not worry about unlocking the 960T.
So which one guys and gals.
Honestly, I think you should go with the zosma. You don't wanna wait on a software development that may or may not give you the push you need to make the 6100 a good buy. The zosma may unlock to a hexacore but with quad core, you will have all you need already if you are only looking for a quad. To be honest, the quad core phenom II's are pretty good for the price already. Consider the 955 as well.
1 - 4 of 4 Posts
