i just finished putting my new computer build together and i installed windows 10 and it says it would restart the computer after it finished installing. it just turned off and did not restart. i had to turn it back on. The asus logo run then i get the overlocking failed error and i get the bios set up and i see that there is a "windows boot manager" on the top of a list for boot priority. bios is 1801. i do not know what is wrong. i've provided pictures below of the bios. i've put the settings on default in the bios. i do not know why it is having an over clocking failed error. i did not over clock anything. please help. i'm looking at my bios, it is reading/ detects my ram, ssd, and processor correctly. so i do not think its because of those. i cna't get my computer to work! help!
Strangely my 2666mhz ram shows as 2133mhz but is detected as 266mhz
These are the kingston hyperx 2666mhz. they have been over clocked to 3200mhz by previous owner before. so it should support xmp. my bios settings are default setting ive changed it couple times to make sure. why is it showing 2133mhz when 2667mhz?
these are the exact one.
http://www.amazon.com/Kingston-2666MHz-Non-ECC-HX426C15...
