The thing to watch with the Torrent compact/nano is if using AIO with rad in front it will limit most high end GPUs as they will be too long.
If you mount rad in bottom most will circulate air and make noise and the pump will die much sooner. So unless using a short GPU most will be limited to using an air cooler in the smaller Torrent. I have the full size Torrent with 420 AIO in front and it works great.
In the 1st pic I rotated the block to test temps sideways but normally I run it turned vertically.
